System visualization (Water Overlay)
Revision as of 10:21, 26 April 2024 by Frank@tygron.nl (talk | contribs)
When a Water Overlay is active, the water system and hydraulic constructions are schematically visualized to provide more insight. If water has flowed through any of the hydraulic constructions, animated arrows in the connecting lines will indicate that movement. Also, when zoomed in on the constructions, the Water level at either side of the construction is visible. Below an overview of the different components in the water system.
Water Objects
Type Image Description
Water area Water area Each Water area is visualized by a dashed border along the surface of the Terrain.
Breach Breach A Breach area is visualized by a purple sphere.
Weir Weir Schematic visualization of a Weir. The water levels at either side and also the direction of the flow is visible.
Culvert Culvert Schematic visualization of a Culvert. The water levels at either side and also the direction of the flow is visible.
Pump Pump Schematic visualization of a Pump. The water levels at either side and also the direction of the flow is visible.
In- or Outlet Inlet Schematic visualization of an Inlet or Outlet.
Sewer overflow Sewer overflow The Sewer overflow is visualized with a black sphere.
Sewer area Sewer area The Sewer area is visualized with an orange line which connects the center of the area with the Sewer overflow.
Water Area Visualization
Water Area Coloring
Type Image Overview Description
Water area is connected and initially water is flowing out of it . Water area connected to another area and water is flowing out. Light blue color indicates that water level is within 0.1m of the initial water level. The number indicates the output datum height a or [[b of the water level
Water area not connected or initially no water flowing out of it Water area connected to another area, but water is flowing out.
Water area is connected and initially water is flowing out of it . Water area connected to another area and water is flowing out. Orange color indicates that the water level has lowered more than 0.1m compared to the initial water level
Water area is not connected and initially water is flowing in to it. However, water is now flowing out. . Water area connected to another area and water is flowing back from an initial end point, indicated by the red line. Orange color indicates that the water level has lowered more than 0.1m compared to the initial water level
Visualization options
In step 4 Interaction of the Water Overlay Wizard different options for visualizing the water system can be selected. Notice that multiple options at once can be selected.
Display Water Objects
This mode is by default selected and will schematically visualize the water system and hydraulic constructions as seen above.
Display Water Area System
Water area system visualization, with the orange line indicating a pump and the blue lines weirs and culverts.
This option adds a schematic line visualization which is visible when zooming out. The direction, flow of the water and the water levels can be seen.
The dots indicate the center location of the water area. Its color indicate whether the water level has:
  • risen; colored dark blue.
  • lowered; colored orange.
  • stayed roughly the same, colored cyan; The acceptable range is 0.1 meters compared to the original water level.
This mode is useful for debugging the water system.
Display Weirs with Panels
Weir panel
When present, Weirs will be visualized with a Panel Popup. It is possible to click on this popup to open the Panel and change the Weir height. Note that a Test Run will start when changing this height. The panels are Template Excel panels which can be downloaded and adjusted as desired.
Display Water Areas with Panels
Water area panel
When present, Water areas will be highlighted with a Panel Popup. When clicking on this popup, the Panel opens and it is possible to change dynamically the Water level. Note that a Test Run will start when changing the Water level. The panels are Template Excel panels which can be downloaded and adjusted as desired.
