Drainage formula (Water Overlay)
Revision as of 17:15, 4 December 2020 by Frank@tygron.nl (talk | contribs)
Drainage passive
First the flow capacity is calculated
Qp,t=Δtqt
Qb=Adfs(wgww)AwAdfs+Aw
if ww>wg then:
Qmax=Aw(wwzw)
else:
Qmax=Ad(wdzd)fs
Qd=min(Qp,t,Qb,Qmax)
Where:
wg is the ground water level in meters
ww is the water level in the waterway
zd is the drainage datum height in meters.
Ad is the drainage area size in square meters.
Aw is the waterway area size in square meters.
zw is the max waterway height.
fs is the average storage percentage of the ground above the drainage.
Qb is the amount transferred for a balanced ground and surface water level
Qmax is the amount available in the ground above the drainage.
Qpt is the drainage capacity at time t
Qd is the actual drained volume at time t
Drainage active
Case 1: Active Draining:
If a positive Pump q is defined:
Qp,t=Δtqt
Qg,t=(wg,tzd)fs
If an overflow threshold T_{o,t} is defined as well:
Qo,t=max(0,To,twt,w)
The actual water pumped out of the drainage system is calculated. If any of the terms are undefined, they are not included.
Qt=max(0,min(Qg,t,Qo,t,Qp,t))
Case 2: Active Reverse Draining:
If a negative Pump q is defined:
Qp,t=Δtqt
Qw,t=min(0,zwwt,w)
Qo,t=min(0,To,twt,w)
The actual water pumped into the drainage system is calculated. If any of the terms are undefined, they are not included.
Qt=max(0,max(Qp,t,Qw,t,Qo,t))
Where:
A negative pump Q can potentially raise the ground water level at the drainage that it reaches the surface above the drainage.
Structures
Drainage
Models
Surface model
Underground model
