Drainage passive
First the flow capacity is calculated
if
then:
else:
Drainage active
Case 1: Active Draining:
If a positive Pump q is defined:
![{\displaystyle Q_{p,t}=\Delta t\cdot q_{t}}](https://wikimedia.org/api/rest_v1/media/math/render/svg/3fefddd36533ea589c2445523dc1ca39522f9154)
If a lower threshold Tl,t is defined as well:
![{\displaystyle Q_{l,t}=min(0,w_{l,t}-T_{l,t})}](https://wikimedia.org/api/rest_v1/media/math/render/svg/de08fa4e2beb119a0567ea6b168ac38ed5f71396)
If an upper threshold T_{u,t} is defined as well:
![{\displaystyle Q_{u,t}=max(0,T_{u,t}-w_{t,u})}](https://wikimedia.org/api/rest_v1/media/math/render/svg/241ee534bb3fdc744d375e07c2ce8eb77c820a55)
If a capacity Qtotal is defined:
![{\displaystyle Q_{c}=Q_{total}-\sum _{0..t-1}Q_{i}}](https://wikimedia.org/api/rest_v1/media/math/render/svg/fbc049dc51fc4dc6b4da7b9a3bd0ca12b4367efe)
After calculating the capacities, the actual water pumped upwards is calculated. If any of the terms are undefined, they are not included.
![{\displaystyle \Delta w={\frac {max(0,min(Q_{l,t},Q_{u,t},Q_{t},Q_{c}))}{A}}}](https://wikimedia.org/api/rest_v1/media/math/render/svg/c9628e2192f7cbe5ae84fc9aa27a16e69ac069be)
Case 2: Active Reverse Draining:
If a negative Pump q is defined:
![{\displaystyle Q_{l,t}=max(0,w_{l,t}-T_{l,t})}](https://wikimedia.org/api/rest_v1/media/math/render/svg/1955af34d02e9c47be051012c9a368c420a3c36d)
If an upper threshold Tu,t is defined as well:
![{\displaystyle Q_{u,t}=min(0,T_{u,t}-w_{t,u})}](https://wikimedia.org/api/rest_v1/media/math/render/svg/3bc50d3919b72c420c40bdf078f49220b247ca3e)
![{\displaystyle Q_{c}=Q_{total}-abs(\sum _{0..t-1}Q_{i})}](https://wikimedia.org/api/rest_v1/media/math/render/svg/40d8542b339bf58d5c3baa6db4e785f18a59f71a)
![{\displaystyle \Delta w={\frac {max(0,max(Q_{l,t},Q_{u,t},Q_{t},-Q_{c}))}{A}}}](https://wikimedia.org/api/rest_v1/media/math/render/svg/5e763f4a29fc7f2eec2213e4a12ef8c64b1bcfaa)
Where:
is the ground water level in meters
is the water level in the waterway
is the drainage datum height in meters.
is the drainage area size in square meters.
is the waterway area size in square meters.
is the max waterway height.
is the average storage percentage of the ground above the drainage.
is the amount transferred for a balanced ground and surface water level
is the amount available in the ground above the drainage.
is the drainage capacity at time t
is the actual drained volume at time t
Related
- Structures
- Drainage
- Models
- Surface model
- Underground model
