Drainage formula (Water Overlay)
Revision as of 15:19, 4 December 2020 by Frank@tygron.nl (talk | contribs)
Drainage passive: First the flow capacity is calculated
Qp,t=Δt⋅qt
Qb=Ad⋅fs⋅(wg−ww)⋅AwAd⋅fs+Aw
if ww>wg then:
Qmax=Aw⋅(ww−zw)
else:
Qmax=Ad⋅(wd−zd)⋅fs
Qd=min(Qp,t,Qb,Qmax)
Drainage active:
Where:
wg is the ground water level in meters
ww is the water level in the waterway
zd is the drainage datum height in meters.
Ad is the drainage area size in square meters.
Aw is the waterway area size in square meters.
zw is the max waterway height.
fs is the average storage percentage of the ground above the drainage.
Qb is the amount transferred for a balanced ground and surface water level
Qmax is the amount available in the ground above the drainage.
Qpt is the drainage capacity at time t
Qd is the actual drained volume at time t
Structures
Drainage
Models
Surface model
Underground model
