Timestep formula (Water Overlay)
Revision as of 12:07, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
- ↑ Jump up to: 1.0 1.1 Kurganov A, Petrova G (2007) ∙ A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ p 15 ∙ found at: http://www.math.tamu.edu/~gpetrova/KPSV.pdf (last visited 2018-06-29)
