Water Overlay
Variants
A Water Module will be initialized by adding one of the following Overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases. This means that each of these overlays is based on the same theory and calculation method, however they are customized to conveniently provide insight in different aspects of the Water Module.
Rainfall Overlay | provides insight into the water stress and impact caused by (excessive) rainfall |
Flooding Overlay | provides insight into water stress and impact caused by breaches in levees or other sources causing excessive water inflow |
Groundwater Overlay | provides insight into long-term processes of water flow both on the surface and underground |
Results
With a Water Overlay, one can generate different kinds of results. For further information about these outcomes, see also results and result types.
- Add and remove an overlay
- Configure a Water Overlay
- Edit an overlay legend
- Combine with Subsidence Overlay
Quick overview
Features and components
- Water Module Attributes
- Hydrological Attributes of Constructions
- Hydrological Attributes of Terrains
