Select lotpolygons (TQL)
Revision as of 12:19, 8 October 2026 by Frank@tygron.nl (talk | contribs)
Representation of select lotpolygons.
Allowed clause parameters
  • The returned result is a MultiPolygon in GeoJSON format.
  • When used in a panel and the panel is opened, the first returned Polygon of the MultiPolygon is highlighted in the 3D Visualization. It is also possible to cycle through and highlight the other returned Polygons.
  • Similar behavior for executed Select lotpolygons queries can be found in the Query Tool.
  • Select lotpolygons queries process Buildings, but not Plots; use Select landpolygons instead.
  • Since a cell in Excel can only hold a limited amount of characters, the value written to named cells with Select lotpolygon queries is 1 if any polygons were returned and 0 if not.
API Endpoints
