Api session query
API Base URL: api/session/query/
GET {query}
API Endpoint: api/session/query/{query}
Parameters:
Name Location Type Default value
query Path String
value Query String 0.0
f Query Format JSON
validate Query boolean false
crs Query String EPSG:3857
Examples
SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_PAVED_AREA?crs=3857&f=JSON&token=API_TOKEN
POST query
Content-Type: application/x-www-form-urlencoded
Parameters:
f Query Format JSON
POST query
Content-Type: application/json
Parameters:
f Query Format JSON
Examples
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query 1"'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query 1", "TQL Query 2", "TQL Query 3" ]'
JavaScript example POST:
 body: '"TQL Query 1"'
fetch("https://engine.tygron.com/api/session/query/", options)
