X (TQL)
Instead of specifying a clause parameter with a particular Item ID, it is possible to use the 'X' character for its value. Using 'X' automatically creates a TQL statement for every Item ID associated with that Clause Parameter in the project data. These statements are processed as an array, returning a corresponding array of results.
Clause Parameters
The X value can be used in the following TQL Clause parameters:
- Address (TQL Param)
- Area (TQL Param)
- Building (TQL Param)
- Category (TQL Param)
- Function (TQL Param)
- Global (TQL Param)
- Grid (TQL Param)
- Gridtype (TQL Param)
- Index (TQL Param)
- Indicator (TQL Param)
- Layertype (TQL Param)
- Levee (TQL Param)
- Map (TQL Param)
- Measure (TQL Param)
- Neighborhood (TQL Param)
- Net line (TQL Param)
- Net type (TQL Param)
- Net function (TQL Param)
- Net load (TQL Param)
- Net cluster (TQL Param)
- Overlay (TQL Param)
- Panel (TQL Param)
- Stakeholder (TQL Param)
- Terrain (TQL Param)
- Timeframe (TQL Param)
- Zone (TQL Param)
Example
Consider the following (simplified) Neighborhood data of a project:
{ "id" : 0, "name" : "De Manege" },
{ "id" : 1, "name" : "De Lancaster" },
{ "id" : 2, "name" : "De Landstreken" },
{ "id" : 3, "name" : "De Kruidentuin" },
{ "id" : 4, "name" : "Golfresidentie" }
The statement
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_X
is expanded into the following comma-separated list:
[ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0, SELECT_NAME_WHERE_NEIGHBORHOOD_IS_1, SELECT_NAME_WHERE_NEIGHBORHOOD_IS_2, SELECT_NAME_WHERE_NEIGHBORHOOD_IS_3, SELECT_NAME_WHERE_NEIGHBORHOOD_IS_4 ]
Its result will be a list of names, separated by comma's, for example:
[ "De Manege", "De Lancaster", "De Landstreken", "De Kruidentuin", "Golfresidentie" ]
