Categorymult (TQL Param)
| Param | Value | Description | Limits search polygon |
| CATEGORYMULT | Category Value | Multiply the calculated value with this Category Value of a Building. | false |
Available for
- This clause can only be used with the specified attribute of Category Values
- This clause should generally be used for Select floorsize (TQL).
- In case this clause is used in combination with the Category (TQL Param), this category value is only multiplied for that category.
- In case this clause is not used in combination with the Category (TQL Param), the weighted average of this value is calculated, using a Building's Categories and their Category weight (Category Value).
API Endpoints
