Height sector
Revision as of 14:39, 22 September 2026 by Frank@tygron.nl (talk | contribs)
Height sectors in relation to Terrains and Elevation GeoTIFFs.
A height sector stores the height data for the Elevation model. Each height sector is a square tile of 500m x 500m. Height values are stored in meters with a precision of 3 decimals. The number of points per height sector depends on the DEM resolution configured in the New Project Wizard's advanced options during project creation and cannot be changed later.
Height sectors are not directly accessed in the editor, but can be manipulated indirectly using the terrain height brush or by applying Elevation GeoTIFFs.
Heightmap Option
The Heightmap option is stored as an enumeration in the Geo Option HEIGHTMAP_RESOLUTION.
Enum Point distance (meter) Height points per sector
SUPER 0.25 2000 x 2000 points
HIGH 0.5 1000 x 1000 points
NORMAL 1.0 500 x 500 points
LOW 2.5 200 x 200 points
BASIC 10.0 50 x 50 points
