External water level (Water Overlay)
EXTERNAL_WATER_LEVEL | m + datum | -10000 to 10000 | The water level of the external water body behind the breach. The initial value assigned to the water level. | 0 |
- When a breach input area is defined, an external water body will not be created. Subsequently, the EXTERNAL_SURFACE_LEVEL, EXTERNAL_WATER_LEVEL and EXTERNAL_AREA attributes will be ignored.
- The Object datum output b can be used to verify the external water level at each recorded timeframe.
- The Object datum output a can be used to verify the water level inside the project area, at each recorded timeframe .
