| Name |
Attribute |
Unit |
Range |
Description |
| Heat flow change per year |
HEAT_FLOW_M2_CHANGE_PER_YEAR |
m²/year |
-1.7976931348623157E308 to 1.7976931348623157E308 |
For any net load connected to an address part of a Building of this function, the amount of resources (FLOW) requested in addition to those in the starting year during every subsequent year. The amount of resources requested starts at HEAT_FLOW_M2_START_VALUE in the start year, and is then increased by this value every year until the building's year of creation, and finally multiplied by the size of the address(es) the net load is associated with to get a default FLOW value for the net load. |
| Heat flow formula start year |
HEAT_FLOW_M2_START_YEAR |
year |
0 to 3000 |
For any net load connected to an Address part of a Building of this function, the start year for the calculation of the amount of resources (FLOW) requested. The amount of resources requested starts at HEAT_FLOW_M2_START_VALUE in this year, and is then increased by HEAT_FLOW_M2_CHANGE_PER_YEAR every year until the building's year of creation, and finally multiplied by the size of the address(es) the net load is associated with to get a default FLOW value for the net load. |
| Heat flow to power multiplier |
HEAT_POWER_TO_FLOW_MULTIPLIER |
factor |
For any net load connected to a building of this function, this divisor converts the automatically calculated FLOW to POWER (POWER = FLOW / multiplier). Explicitly defined FLOW attributes are ignored. |
| Heat flow value at start year |
HEAT_FLOW_M2_START_VALUE |
m² |
-100 to 100 |
The amount of resources (FLOW) requested by a net load in the starting year. This value increases via HEAT_FLOW_M2_CHANGE_PER_YEAR until the building's construction year, then is multiplied by the associated address size to determine the default FLOW. |
