Terrain water manning (Water Overlay)
Revision as of 14:56, 6 October 2022 by Maxim@tygron.com (talk | contribs)
Icon | Attribute | Unit | Layer | Range | Description |
WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the terrain |
Terrains have an inherent "roughness", affecting the flow of water across their surface, which is expressed by the Gauckler–Manning coefficient or, in short, Manning's value (n).
- The manning value can alternatively be provided as a prequel.
- The default values for this attribute are derived from online accessible databases[1] and are readily adjusted by the user.
- If a building is present on the terrain, the WATER_MANNING value of the building is used instead.
- Only terrains of type 'surface' have an assigned WATER_MANNING.
- ↑ WikiEngineer (2008-2011). Manning Roughness Coefficients. Retrieved from: http://wikiengineer.com/Water-Resources/ManningRoughnessCoefficients
