Rain area (Water Overlay)
Revision as of 14:09, 10 February 2021 by Rudolf@tygron.nl (talk | contribs)
A Rain area is a feature which can override the Weather's rain with a different array of values. This allows users to simulate rain clouds moving over the project area.
RAIN_M | end-time, m | An array of values, each pair indicating until what time that period of rain will last and how much rain will fall in that period. | n/a |
- A maximum of 10.000 values (5.000 pairs) can be defined per rain area.
- Up to 100 rain areas per water overlay are supported.
- For locations without a rain area, the Weather's rain m is applied.
- The configured Weather dictates the simulated time and optional starting date. If the rain sequence of the Rain area is defined beyond the duration of the Weather time sequence, the excess of the Rain area time sequence is ignored. If the Rain area's time sequence ends before the Weather's time sequence, the remainder of the time sequence of the Rain area is considered to be 0;
