Bridge elevation (Water Overlay)
Revision as of 10:35, 8 January 2021 by Godelief@tygron.com (talk | contribs)
| INCLUDE_BRIDGE_ELEVATION | boolean | Whether to include bridges in the elevation model used for the water calculations. | n/a |
This attribute defines whether to include bridges and other floating buildings in the elevation model used for the water calculations.
- This attribute is by default set to 0 which means bridges are not included so water can flow under the bridge.
- In the advanced settings step of the Water Overlay Wizard, this attribute can also be (de)activated.
- For more control, you can also set this attribute to 1 and use a square culvert to regulate water flowing under a bridge.
