Limitation area (Water Overlay)
Revision as of 13:54, 14 February 2020 by Rudolf@tygron.nl (talk | contribs)
This article is a stub.
A Limitation area is a feature which can direct the Water Overlay to restrict its calculations to specific locations. When the LIMIT_RAIN attribute of the overlay is set to the appropriate value, calculations only occur in the locations indicated by the Areas with a LIMIT_AREA attribute. Template:Overlay attribute
- Limitation areas only determine the extent of the calculations when the LIMIT_RAIN attribute of the overlay is set to the appropriate value. Otherwise, the Limit areas do not affect any facet of the calculation.
