Breach (Water Overlay)
Revision as of 14:10, 1 November 2019 by Frank@tygron.nl (talk | contribs)
A breach is a modification to the terrain height, with an optional in- or outflow of water for the hydrological model. This can be used to represent calamitous situations, such as a breach in a levee. Breaches can also be used to easily simulate a terrain height increase, like a levee.
The breach can grow over time, based on its initial width and the critical speed at which water may flow. If a BREACH_WIDTH is defined, the breach's polygon is intersected with a circle emanating from the centerpoint of the polygon. It is only in that intersection, dubbed the "active breach", that water will flow in from the simulated external water body. The radius of the circle defining the intersection will expand as water flows, based on the critical speed of the water as defined in the BREACH_SPEED attribute. All cells in the active breach are considered directly adjacent to the external water body.
The terrain covered by the entire breach area is considered lowered to the height defined by its BREACH_HEIGHT attribute, even if the active breach does not extend across the entirety of the breach area.
Water flowing through or across a breach will flow in the direction defined by the BREACH_ANGLE attribute, regardless of whether the water flowed onto the breach from elsewhere in the water model, or from the simulated external water body. If no BREACH_ANGLE is defined, water can flow in any direction.
Template:Overlay attribute
