Terrain water manning (Water Overlay)
Template:Overlay attribute
Manning's n (terrain)
Terrains have an inherent "roughness", affecting the flow of water across its surface, which is expressed by the Gauckler–Manning coefficient or, in short, Manning's value (n).
  • The default values for this attribute are derived from online accessible databases[1] and are readily adjusted by the user.
  • If a construction is present on the terrain, the WATER_MANNING value of the construction is used instead.
  • Only terrains of type 'surface' have an assigned WATER_MANNING.
The default value for the WATER_MANNING attribute of surface type "Open land". The user can change this value.
  1. WikiEngineer (2008-2011). Manning Roughness Coefficients. Retrieved from: http://wikiengineer.com/Water-Resources/ManningRoughnessCoefficients
