How to edit Cinematics
Editor → Tools (Ribbon tab) → Cinematics (Ribbon bar)
The right panel allows you to edit the properties of cinematics.
The right panel allows you to edit properties of cinematics and also provides access to additional functions. Cinematics also contain keypoints, which define the path the cinematic takes through project map. Cinematics can be activated with events in the 3D Visualization.
Name
The field for the "name".
The name of the cinematic. It appears in the text panel during pauses and helps differentiate cinematics in the editor.
Video recording
A link to the video recording panel.
A link to the Video Recording panel. Cinematics and video recording can be used in conjunction with each other. This is not an editable property.
Start cinematic
A button to start the cinematic.
Starts the selected cinematic. This is useful to test the cinematic. Note that this also starts a test run. This is not an editable property.
