How to edit Key Points
Cinematics are defined by keypoints. These determine the path that the cinematic takes. Additionally, a keypoint can also determine what happens when that point is reached, such as the activation of events or the display of text. A cinematic should have at least 1 keypoint.
Creating and removing keypoints
How to add a new keypoint:
- Select "Visuals" in the ribbon header.
- Select "Cinematics" in the ribbon bar.
- Select the cinematic you want to add the keypoint to in the Left Panel.
- If there is already at least one keypoint present, select the keypoint you want the new keypoint to be added after.
- Select "Add Key Point".
How to remove an existing keypoint:
- Select the cinematic from which you wish to remove a keypoint.
- Select the keypoint you wish to remove.
- Select "Remove".
Changing keypoint properties
Editor → Tools (Ribbon tab) → Cinematics (Ribbon bar) → The Cinematic to edit (Left panel) → The keypoint to edit (Sub-option)
When a specific keypoint is selected, you are able to edit its properties in the right panel. Selecting a keypoint automatically aligns the camera with that point's location and direction. This matches the exact orientation the camera will have when passing this keypoint during playback.
Description
- The description of the keypoint. This is the text that will be displayed to the user when the cinematic reaches this point.
Paused
- The pausing property of the keypoint. When this checkbox is checked, the cinematic will pause when it reaches this point, until the user chooses to continue.
Time
- The time in seconds to travel between this keypoint and the next keypoint. A lower number means the camera will travel faster between the two keypoints. You can change the time by altering the number in the text field. If the specified time is too short, it will be automatically increased to limit the camera's speed.
Time Slider
- This slider allows you to see the orientation and location of the camera at any time between this keypoint and the next. By moving the slider, you move the camera between the selected keypoint and the next by the same relative amount. This is not an editable property.
Fired Events
- Main article: Events
- The event bundles which will be fired when this keypoint is reached. This allows events to take place at given points during a cinematic. Add event bundles using the dropdown and "Add" button; remove them by selecting a bundle and clicking "Remove Event Bundle"
Edit Camera Position
- This button activates the camera editing mode. In this mode, it is possible to move the camera, and orient it in any direction. This saves the current location and orientation for when the cinematic reaches this keypoint.
- How to create an HD Movie or Video Recording from the cinematic
- How to create or remove Cinematics
- How to edit Cinematics
- How to edit the Camera Position
- How to couple Cinematics to Stakeholders
API Endpoints
- Api session event editor cinematic add keypoint
- Api session event editor cinematic remove keypoint
- Api session event editor cinematic set keypoint description
- Api session event editor cinematic set keypoint paused
- Api session event editor cinematic set keypoint time
- Api session event editor cinematic set keypoint orientation
- Api session event editor cinematic add keypoint event bundle
- Api session event editor cinematic remove keypoint event bundle
