Sewer pump speed (Water Overlay)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define how fast water is removed from the model.
  • Water pumped out of a sewer cannot be pumped back once it is in the external area.
  • The sewer pump speed may never be negative, as this would conceptually result in water being pumped into the sewer from outside the project area.
  • When using a dynamic SEWER_PUMP_SPEED, a maximum of 10.000 values (5.000 pairs) can be defined.
API Endpoints
