Api session event editor setting
API Endpoint: api/session/event/editorsetting/
API Endpoints for Setting editing.
Name Description
add_crs Set a CRS to the recently used CRSs array
get_epoch_time Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local time in this Project
get_sun_altitude Get Sun Altitude value for local time in this Project
get_sun_azimuth Get Sun Azimuth value for local time in this Project
get_sun_motion Get Sun Motion value for local time in this Project (The Netherlands only)
remove_crs Remove a CRS from the recently used CRSs array
set_ai_editing Set if AI Agents are allowed to edit Project data
set_currency Set which the Currency is displayed in the interface
set_decimals Set how many decimal places Attributes are allowed to have
set_default_geoplugin Set the Default Geo Plugin of a Maplink, used in the Geo Import Wizard
set_export_crs Set the Default Export CRS, used in Item Export Panels
set_grid_cell_size Change the Project's grid cell size, used by active Overlays
set_import_crs Set the Default Import CRS, used in the Geo Import Wizard
set_limit_map Set Project Map Limit Area
set_panel_availability Restrict which Panels are active or inactive in a Project
set_permission_popup_active Set whether permission Popups for spatial Actions are active in a Project
set_rasterization Set the rasterization method used by the Rasterizers in a Project
set_region Set the Region of a Project
set_setting Set Project wide Setting
set_sun_dates Set the Dates between which the Sun movement is interpolated in the 3D Visualization
set_timestamp_format Set the timestamp Format for Dates and Times, used for displaying Dates and Times
set_tql_token Set if TQL Queries are allowed access the API token
set_unit_system_type Set the Unit System of a Project, used in the interface
set_wind_speed Set the Wind Speed
wizard_finished Manually finish the Geo Wizard process. (Triggered automatically at the end of the New Project Wizard.)
