Api session event editor setting set export crs
API Endpoint: api/session/event/editorsetting/set_export_crs/
Description: Set the Default Export CRS, used in Item Export Panels
0 REQUIRED (String) EPSG CRS Code
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_export_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"EPSG CRS Code"'
JavaScript example POST
 body: '"EPSG CRS Code"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_export_crs/", options)
