Api session event editor setting set grid cell size
API Endpoint: api/session/event/editorsetting/set_grid_cell_size/
Description: Change the Project's grid cell size, used by active Overlays
| 0 | REQUIRED | (Floating point number) | grid cell size in meters |
| 200 | Boolean (Value is updated) |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_grid_cell_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '12'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_grid_cell_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '57'JavaScript example POST
body: '12'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_grid_cell_size/", options)
