Api session event editor setting set import crs
API Endpoint: api/session/event/editorsetting/set_import_crs/
Description: Set the Default Import CRS, used in the Geo Import Wizard
0 REQUIRED (String) EPSG CRS Code
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"EPSG CRS Code"'
JavaScript example POST
 body: '"EPSG CRS Code"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/", options)
