Api session event editor setting add crs
API Endpoint: api/session/event/editorsetting/add_crs/
Description: Set a CRS to the recently used CRSs array
0 REQUIRED (String) EPSG CRS Code
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/add_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"EPSG CRS Code"'
JavaScript example POST
 body: '"EPSG CRS Code"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/add_crs/", options)
