Api session event editor setting set tql token
API Endpoint: api/session/event/editorsetting/set_tql_token/
Description: Set if TQL Queries are allowed access the API token
0 REQUIRED (true, false) True for allow, false to disable TQL API tokens true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_tql_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript example POST
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_tql_token/", options)
