Api session event editor setting set ai editing
API Endpoint: api/session/event/editorsetting/set_ai_editing/
Description: Set if AI Agents are allowed to edit Project data
0 REQUIRED (true, false) True for allow, false to disable editing true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_ai_editing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript example POST
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_ai_editing/", options)
