Api session event editor setting remove crs
API Endpoint: api/session/event/editorsetting/remove_crs/
Description: Remove a CRS from the recently used CRSs array
| 0 | REQUIRED | (String) | EPSG CRS Code |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/remove_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"EPSG CRS Code"'JavaScript example POST
body: '"EPSG CRS Code"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/remove_crs/", options)
