Api session event editor setting set wind speed
API Endpoint: api/session/event/editorsetting/set_wind_speed/
Description: Set the Wind Speed
| 0 | REQUIRED | (Floating point number) | Wind Speed (m/s) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '24'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '79'JavaScript example POST
body: '24'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/", options)
