Api session event editor measure
Revision as of 10:22, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/
API Endpoints for Measure editing.
Name Description
add Add Measure for Stakeholder
duplicate Duplicate specified Measures
remove Remove existing Measure
set_name Set the name of a Measure
Additional API Endpoints:
Name Description
add_building Add a new Building to specified Measures
add_event Add a new event to a Measure for a specific Action Type
add_geotiff Add a new GeoTIFF Spatial to a Measure
add_geotiff_polygons Add Polygons to pre-existing Polygons of a GeoTIFF Spatial of a Measure
add_grid Add a new Grid Spatial to a Measure
add_grid_polygons Add Polygons to pre-existing Polygons of a Grid Spatial of a Measure
add_levee Add a new Levee Spatial of a specified Levee to a Measure
add_levee_polygons Add Polygons to pre-existing outer (or inner) Polygons of a Levee Spatial of a Measure
add_terrain Add a new Terrain Spatial to a Measure
add_terrain_polygons Add Polygons to pre-existing outer (or inner) Polygons of a Terrain Spatial of a Measure
add_upgrade Add a new Upgrade Spatial to a Measure
add_upgrade_polygons Add Polygons to pre-existing Polygons of an Upgrade Spatial of a Measure
duplicate_building Duplicate specified Measure Buildings
import_buildings Import Measure Building Collection
import_geotiffs Import Measure GeoTIFF Collection
import_grids Import Measure Grid Collection
import_levees Import Measure Levee Collection
import_terrains Import Measure Terrain Collection
import_upgrades Import Measure Upgrade Collection
remove_event Remove a specific Server or Client side Coded Event from a Measure for a specific Action Type
remove_geotiff Remove specified GeoTIFF Spatial from a Measure
remove_geotiff_polygons Remove Polygons from pre-existing Polygons of a GeoTIFF Spatial of a Measure
remove_geotiff_terrain_type Remove the Terrain Type of a GeoTIFF Spatial of a Measure
remove_grid Remove specified Grid Spatial from a Measure
remove_grid_polygons Remove Polygons from pre-existing Polygons of a Grid Spatial of a Measure
remove_grid_terrain_type Remove the Terrain Type of a Grid Spatial of a Measure
remove_levee Remove specified Levee Spatials from a Measure
remove_levee_polygons Remove Polygons from pre-existing Polygons of a Levee Spatial of a Measure
remove_terrain Remove specified Terrain Spatials from a Measure
remove_terrain_polygons Remove Polygons from pre-existing outer (or inner) Polygons of a Terrain Spatial of a Measure
remove_upgrade Remove specified Upgrade Spatials from a Measure
remove_upgrade_polygons Remove Polygons from an Upgrade Spatial of a Measure
set_cost Set the Cost of a Measure for a specific Cost type (construction, demolition) and whether it is fixed or per cubic meter
set_description Set the description of a Measure
set_event Change an pre-existing event of a specific Action Type of a Measure
set_geotiff Change the GeoTIFFs applied by a specified Measure
set_geotiff_automatic_polygons Let the Polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF Spatial of a Measure
set_geotiff_terrain_type Set the Terrain Type for a GeoTIFF Spatial of a Measure
set_grid Change the Grids applied by a specified Measure
set_grid_automatic_polygons Automatically calculate Polygons based on the Overlay specified in the Grid Spatial of a Measure
set_grid_terrain_type Set the Terrain Type for a Grid Spatial of a Measure
set_image Set the image of a Measure
set_levee_angle Set the angle of a Levee Spatial of a Measure
set_levee_height Set the inner height of a Levee Spatial of a Measure
set_levee_height_relative Set whether the inner height of a Levee Spatial of a Measure is considered relative
set_levee_type Set the Levee for a specified Levee Spatial of a Measure
set_owner Set the owner of a Measure
set_requires_confirmation Set whether the Measure should be confirmed by other Stakeholders
set_terrain_edit_type Set the Edit Type of a Terrain Spatial of a Measure. This changes the way the Terrain height is adjusted: lowered, flattened or raised
set_terrain_height Set the inner height of a Terrain Spatial of a Measure
set_terrain_height_relative Set whether the inner height of a Terrain Spatial of a Measure is considered relative
set_terrain_type Set the Terrain Type for a Terrain Spatial of a Measure
set_upgrade_type Set the Upgrade Type for an Upgrade Spatial of a Measure
