Api session event editor measure import upgrades
API Endpoint: api/session/event/editormeasure/import_upgrades/
Description: Import Measure Upgrade Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Upgrade Geometries
1 REQUIRED (UPGRADE_TYPE Integer ID or multiple integer values in array [1, 2, 3]) Upgrade Types
2 OPTIONAL (MEASURE Integer ID) Measure (pre-existing) (optional)
3 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
4 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer (Measure ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_upgrades/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1 ]
Curl example multi item POST
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ 1, 2, 3 ] ]
JavaScript example POST
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_upgrades/?crs=3857", options)
