Api session event editor measure remove terrain
API Endpoint: api/session/event/editormeasure/remove_terrain/
Description: Remove specified Terrain Spatials from a Measure
0 REQUIRED (MEASURE Integer ID) Measure
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Terrain Spatial IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_terrain/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_terrain/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/remove_terrain/", options)
