Api session event editor measure add grid
API Endpoint: api/session/event/editormeasure/add_grid/
Description: Add a new Grid Spatial to a Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure |
| 200 | Grid Spatial ID |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_grid/", options)
