Api session event editor measure add terrain polygons
API Endpoint: api/session/event/editormeasure/add_terrain_polygons/
Description: Add Polygons to pre-existing outer (or inner) Polygons of a Terrain Spatial of a Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure | |
| 1 | REQUIRED | (Integer number) | Terrain Spatial ID | |
| 2 | REQUIRED | (true, false) | Is Outer (false = inner) | true or false |
| 3 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_terrain_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, true, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
'JavaScript example POST
body: '[ 1, 1, true, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_terrain_polygons/?crs=3857", options)
