Api session event editor measure remove event
API Endpoint: api/session/event/editormeasure/remove_event/
Description: Remove a specific Server or Client side Coded Event from a Measure for a specific Action Type
| 0 | REQUIRED | (MEASURE Integer ID or multiple integer values in array [1, 2, 3]) | Measures | |
| 1 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | Server Side (false = Client Side) | |
| 2 | REQUIRED | (ActionType or multiple values in array [a, b, c]) | Action Types | |
| 3 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Coded Event IDs |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, "CONSTRUCTION_PLAN", 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, true, "CONSTRUCTION_PLAN", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/remove_event/", options)
