Api session event editor measure set cost
API Endpoint: api/session/event/editormeasure/set_cost/
Description: Set the Cost of a Measure for a specific Cost type (construction, demolition) and whether it is fixed or per cubic meter
0 REQUIRED (MEASURE Integer ID) Measure
1 REQUIRED (Enumeration) Cost Type CONSTRUCTION
2 REQUIRED (Floating point number) Cost in valuata
3 REQUIRED (true, false) Fixed (if false, Cost per cubic meter) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_cost/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CONSTRUCTION", 74, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_cost/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CONSTRUCTION", 72, true ]'
JavaScript example POST
 body: '[ 1, "CONSTRUCTION", 74, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_cost/", options)
