Api session event editor measure set levee height relative
API Endpoint: api/session/event/editormeasure/set_levee_height_relative/
Description: Set whether the inner height of a Levee Spatial of a Measure is considered relative
| 0 | REQUIRED | (MEASURE Integer ID) | Measure | |
| 1 | REQUIRED | (Integer number) | Levee Spatial ID | |
| 2 | OPTIONAL | (true, false) | Boolean |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_levee_height_relative/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_levee_height_relative/", options)
