Api session event editor measure add geotiff
API Endpoint: api/session/event/editormeasure/add_geotiff/
Description: Add a new GeoTIFF Spatial to a Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure |
| 200 | Integer (GeoTIFF Spatial ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_geotiff/", options)
