Api session event editor measure import terrains
API Endpoint: api/session/event/editormeasure/import_terrains/
Description: Import Measure Terrain Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Terrain Geometries | |
| 1 | REQUIRED | (Enumeration) | Measure Edit Type | BUILDING, FLATTEN, GEOTIFF, GRID, LEVEE, RAISE, UPGRADE or WATER |
| 2 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | Is Inner | |
| 3 | REQUIRED | (TERRAIN_TYPE Integer ID or multiple integer values in array [1, 2, 3]) | Terrain Types | |
| 4 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Override Inner Heights | |
| 5 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | Height Relative | |
| 6 | OPTIONAL | (MEASURE Integer ID) | Measure (pre-existing) (optional) | |
| 7 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 8 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
| 200 | Integer (Measure ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_terrains/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "BUILDING", true, 1, 1.0, true ]
'Curl example multi item POST
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, "BUILDING", [ true, false, true ], [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ], [ true, false, true ] ]
'JavaScript example POST
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "BUILDING", true, 1, 1.0, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_terrains/?crs=3857", options)
