Api session event editor measure add terrain
API Endpoint: api/session/event/editormeasure/add_terrain/
Description: Add a new Terrain Spatial to a Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure |
| 200 | Integer (Terrain Spatial ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_terrain/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_terrain/", options)
