Api session event editor setting
Revision as of 16:05, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/
API Endpoints for Setting editing.
Name Description
add_crs Set a CRS to the recently used CRSs array.
get_epoch_time Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project
get_sun_altitude Get Sun Altitude value for local Time in this Project
get_sun_azimuth Get Sun Azimuth value for local Time in this Project
get_sun_motion Get Sun Motion value for local Time in this Project (The Netherlands only)
remove_crs Remove a CRS from the recently used CRSs array.
set_ai_editing Set if AI Agents are allowed to edit Project data.
set_currency Set which the Currency is displayed in the interface.
set_decimals Set how many decimal places Attributes are allowed to have.
set_default_geoplugin Set the Default Geo Plugin of a Maplink, used in the Geo Import Wizard.
set_export_crs Set the Default Export CRS, used in Item Export Panels.
set_grid_cell_size Change the Project's grid cell size, used by active Overlays.
set_import_crs Set the Default Import CRS, used in the Geo Import Wizard.
set_limit_map Set Project Map Limit Area
set_panel_availability Restrict which Panels are active or inactive in a Project
set_permission_popup_active Set whether permission Popups for spatial Actions are active in a Project
set_rasterization Set the rasterization method used by the Rasterizers in a Project
set_region Set the Region of a Project
set_setting Set Project wide Setting
set_sun_dates Set the Dates between which the Sun movement is interpolated in the 3D Visualization.
set_timestamp_format Set the timestamp Format for Dates and Times, used for displaying Dates and Times.
set_tql_token Set if TQL Queries are allowed access the API token.
set_unit_system_type Set the Unit System of a project, used in the interface.
set_wind_speed Set the Wind Speed
wizard_finished Manually finish the Geo Wizard process. (Triggered automatically at the end of the New Project Wizard.)
