Terrain water transpiration factor (Water Overlay)
| Icon | Attribute | Unit | Layer | Range | Description |
WATER_TRANSPIRATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the ground. The weather's evaporation speed is multiplied by this factor to determine the rate of transpiration. |
Like buildings configured as crops and foliage, terrains representing plants can use plant-related attributes to draw and evaporate groundwater.
- For plants to evaporate water, both the ROOT_DEPTH_M and the WATER_TRANSPIRATION_FACTOR must be appropriately configured.
- When a Building is present in any given location, the values for evaporation in the ground will overrule any values set by terrain in the same location. To model ground evaporation without a Building, set the attributes of the Building on the applicable terrain type instead.
- Groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE.
- Transpiration is zero when no building is present and the terrain's WATER_TRANSPIRATION_FACTOR is 0.
- Can be configured as a seasonal factor, represented by an array of four values, one for each season. This allows for more evaporation during a crops growth season and less during the winter.
- Water transpiration factor (Water Overlay)
- Groundwater level formula (Water Overlay)
- Ground transpiration formula (Water Overlay)
- Season formula (Water Overlay)
- Ground model (Water Overlay)
- Evapotranspiration model (Water Overlay)
