Current Situation
Revision as of 14:57, 12 October 2026 by Maxim@tygron.com (talk | contribs)
Current Situation represents the original situation of your project. Its counterpart is the Future Design.
Map Type
The Current Situation is linked to the API Map Type CURRENT. Editing it requires the Editor, whereas updating the Future Design requires an action during a Single, multi or Test Run session.
Items can be present in both map types at the same time. This is the case when starting a single, multi or test-run session. After planning begins, buildings appear only in the Future Design if they are planned or upgraded.
Viewer
Buttons in the Top bar of the viewer interface of the Tygron Client allows you to switch between the original and planned map type to inspect the differences visually.
Editor
In the Editor the Current situation tab is also the first of the five ribbon tabs and is located in the top part of the editor interface. The Current situation tab contains tools which relate to the editing, configuring and building of the current situation in the project. The current situation is the starting setting for a project before any planning or analysis is to be performed.
The editor. The Current situation tab is located in the ribbon bar at the top of the editor.
The Current situation tab consists of the following tool options:
Conceptually, the current situation contains these Items.
