Api session event participant
API Endpoint: api/session/event/participant/
API Endpoints for Endpoints for user Actions (e.g., Building construction) in a test run/impact Session.
| Name | Description |
| action_menu_set_active | Set a Category active for a Stakeholder. |
| attribute_action_plan | Apply an Attribute Action. |
| building_plan_construction | Plan a new Building in the MAQUETTE map. |
| building_plan_demolish | Plan the demolition of a Building in the MAQUETTE map. |
| building_plan_demolish_polygon | Plan the demolition of Buildings in the given Polygon in the MAQUETTE map. |
| building_plan_upgrade | Plan the upgrade of Buildings in the given Polygon in the MAQUETTE map. |
| building_revert_polygon | Revert the Polygon to the original state of the current map. |
| event_bundle_apply_server_events | Apply a bundle of events on the server side for a particular Stakeholder. |
| map_buy_land | Buy the land defined by the Polygon for a given price. |
| map_levee | Create a Levee with a given height and Area. |
| map_lower_land | Lower land to create open water. |
| map_raise_land | Raise land by one length unit. |
| map_sell_land | Sell the land defined by the Polygon for a given price. |
| measure_cancel_construction | Cancel a Measure planned by a Stakeholder while in pre-construction phase. |
| measure_plan_construction | Plan construction of a Measure by a Stakeholder that is not yet planned. |
| money_transfer_give | Give money from one Stakeholder to another. |
| net_cluster_set_load_attribute | For each Net Load of a Net Cluster, set the value of the Attribute. |
| net_cluster_set_load_attributes | For each Net Load of a Net Cluster, set the value of the Attributes. |
| net_cluster_set_state | Set the Timestate for all Net Loads of a Net Cluster. |
| net_cluster_set_state_for_net_type | Set the Timestate for Net Loads of a Net Cluster, based on Net Type. |
| net_cluster_set_states | Set the Timestate for all Net Loads of a Net Cluster. |
| panel_answer | Stakeholder has selected an Answer (Panel) in a Panel. |
| parametric_design_plan | Parametric Design Plan |
| popup_answer | Stakeholder Answer (Panel)s a Popup. |
| popup_answer_with_date | Stakeholder Answer (Panel)s a Popup with an additional date. |
| restore_land | Stakeholder restores land to its original state. |
| stakeholder_set_location | Set the location of a Stakeholder in the 3D world. |
| zone_add_function_category | Add a FunctionCategory that is allowed to be built within a Zone. |
| zone_remove_function_category | Remove a FunctionCategory so it cannot be built within the Zone. |
| zones_set_categories | Sets the allowed Building categories for specified Zones. |
