Api session event participant zones set categories
API Endpoint: api/session/event/participant/zones_set_categories/
Description: Stakeholder sets the allowed Function Categories per specified Zone
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (ZONE Integer ID or multiple integer values in array [1, 2, 3]) Zones
2 REQUIRED (Category or multiple values in array [a, b, c]) Array of Category Arrays
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/zones_set_categories/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ [ "NATURE", "NATURE" ], [ "NATURE", "BRIDGE" ], [ "NATURE", "NATURE" ] ] ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/zones_set_categories/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], [ [ "UNDERGROUND", "OTHER" ], [ "UNDERGROUND", "SHOPPING" ], [ "OTHER", "UNDERGROUND" ] ] ]'
JavaScript example POST
 body: '[ 1, 1, [ [ "NATURE", "NATURE" ], [ "NATURE", "BRIDGE" ], [ "NATURE", "NATURE" ] ] ]'
fetch("https://engine.tygron.com/api/session/event/participant/zones_set_categories/", options)
