Api session event participant stakeholder set location
API Endpoint: api/session/event/participant/stakeholder_set_location/
Description: Stakeholder's view is moved to the location in the 3D Visualization
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (Point with crs: EPSG:3857) Point
2 REQUIRED (true, false) Ping others (show them my location) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658712.8315137589, 6799395.908075838 ]
}, true ]
Curl example multi item POST
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658651.7185208196, 6799325.652074346 ]
}, true ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658712.8315137589, 6799395.908075838 ]}, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857", options)
