Api session event participant event bundle apply server events
API Endpoint: api/session/event/participant/event_bundle_apply_server_events/
Description: Stakeholder applies server side events of an Event Bundle
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (EVENT_BUNDLE Integer ID) | Event Bundle |
| 200 | Integer (Action Log ID) |
curl 'https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/", options)
