Api session event participant building plan demolish
API Endpoint: api/session/event/participant/building_plan_demolish/
Description: Stakeholder plan the demolition of an owned Building
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (BUILDING Integer ID) Building
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/building_plan_demolish/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/building_plan_demolish/", options)
